Home > General > Replacement Screwdriver
sjhanson
2006 Range Rover Sport Supercharged Java Black
Does anybody know where I can buy a replacement screwdriver from? ( I want to change my bonnet switch but can't unscrew and remove the old one? )
Thanks,
Shaun
Post #310754 Sun Aug 21 2011 2:28pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Screwdriver ? You sure you meant screwdriver ? Halfords ?
Post #310756 Sun Aug 21 2011 2:44pm
sjhanson
I think so! Confused
The part the bonnet switch is connected to is secured by screws which almost look like I need an Allen key to unscrew, so I am assuming - probably wrongly - that the supplied screwdriver will unscrew these?
If not, does anybody know what screw head this is so I can go to Halfords or wherever to buy the correct item?
Thanks,
Shaun
Post #310758 Sun Aug 21 2011 2:51pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
based on your question, i would strongly advise not going near your vehicle with any tools Whistle
Post #310759 Sun Aug 21 2011 3:25pm
sweetafton
Rolling with laughter
Post #310760 Sun Aug 21 2011 3:34pm
sjhanson
Thanks for the help Rolling Eyes
Post #310767 Sun Aug 21 2011 4:39pm
airwolf222helicopters
torx head on the screw ask in halfords for a mini set of them
Post #310769 Sun Aug 21 2011 4:42pm
Tim in Scotland
Are these not Torqx (spelling??) screws?
Airwolf you just beat me to it! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #310770 Sun Aug 21 2011 4:43pm
Torx (pronounced "torks") developed[when?] by Camcar Textron,[1] is the trademark for a type of screw head characterized by a 6-point star-shaped pattern. People unfamiliar with the trademark generally use the term star, as in star screwdriver or star bits. The generic name is hexalobular internal driving feature and is standardized by the International Organization for Standardization as ISO 10664.[2] Torx Plus is an improved profile.
By design, Torx head screws resist cam-out better than Phillips head or slot head screws. Where Phillips heads were designed to cause the driver to cam out, to prevent over-tightening, Torx heads were designed to prevent cam-out. The reason for this was the development of better torque-limiting automatic screwdrivers for use in factories. Rather than rely on the tool slipping out of the screw head when a torque level is reached, thereby risking damage to the driver tip, screw head and workpiece, the driver design achieves a desired torque consistently. The manufacturer claims this can increase tool bit life by ten times or more.
Torx screws are commonly found on automobiles, motorcycles, bicycle brake systems, hard disk drives, computer systems and consumer electronics. Initially, they were sometimes used in applications requiring tamper-resistance, since the drive systems and screwdrivers were not widely available; as drivers became more common, tamper-resistant variants, as described below, were developed.[3] Today, Torx screws are also becoming increasingly popular in construction industries.
Post #310772 Sun Aug 21 2011 4:50pm
Post #310773 Sun Aug 21 2011 4:51pm
sjhanson
Thanks all (airwolf!)
Post #310786 Sun Aug 21 2011 6:22pm
sjhanson
This look ok?
http://www.halfords.com/webapp/wcs/stores/...yId_165572
Post #310788 Sun Aug 21 2011 6:33pm
If it fits your tools them look fine
I got some torx screwdriver bits in a cheapo set for a fiver and have worked fine for what I needed
Post #310790 Sun Aug 21 2011 6:44pm
rr5port
2010 Range Rover Sport TDV8 HSE Santorini Black
PLEASE PLEASE tell me which Halfords you're going into tomorrow.
I want to see his head explode when you say word for word what airwolf has posted. Rolling with laughter
Post #310794 Sun Aug 21 2011 7:28pm
timcom0
Given the part you want to remove I would use the torx bits for the socket set, just me but a better chance of getting them tightened correctly
Post #310796 Sun Aug 21 2011 7:46pm
