Home > Technical > Help Tow Bar Electrics
mse
Confirmed - they are within the main fuse packs so integral to the cars fuse box. Mike
2014 Facelift Discovery
Post #307909 Sun Jul 31 2011 3:34pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Many thanks, does anybody know the fuse numbers or are they listed in the manual
Post #307910 Sun Jul 31 2011 3:38pm
leedsunited
Ok checked fuses nothing amiss, booked in to dealer Wednesday, issue is that i have trailer that works fine when plugged into other tow electris but when on mine, no brake lights on both sides and know lights at all on passenger side although indicators work, problem is replicated if i plug a tow board in as well. its as iff the passenger side circuit is out as well as brake lights. Sad
Post #308126 Mon Aug 01 2011 8:01pm
mse
Hope you sort it, always annoying when the fuses are fine, especially when the fuses are split like the fault. Mike
Post #308131 Mon Aug 01 2011 8:37pm
leedsunited
Thanks, I will post back once I know, have a mate with a test unit for towing electrics and he is popping round to plug it in tommorow so I should have an independent view before I drop into the dealers. Thumbs Up
Post #308132 Mon Aug 01 2011 8:48pm
airwolf222helicopters
just fitted a O.E.M KIT myself with new loom and fuse block in space in tool kit
my question did you have to get it programmed to car ?
as mine works fine on tow board? without programming ??
dealer said had to be programmed ?
what for if it works ?
let me know Thumbs Up
Post #308382 Tue Aug 02 2011 10:36pm
mse
Cant help you why you have the fuse block still...maybe old stock?
But on programming, its the other towing features you dont get until enabling, like holding gears down hill and disabling the reversing sensors etc.
Ive got to get it round to my mate to have it turned on. Mike
Post #308385 Tue Aug 02 2011 10:43pm
leedsunited
Ok update, the wiring kit does have a fuse block fitted, the dealer found mine behind the panel as I first suspected. Apparently it had been fitted as if it was a D4 install where it is installed behind the acces panel, now installed correctly in boot compartment and blown fuses now replaced. I will post tow electrics part numbers that have fuse loom later. Thumbs Up
Towbar Electrics Wiring harness that has fuse box that should be located in boot compartment:
YWJ500160 & YWJ500150
Post #308463 Wed Aug 03 2011 12:58pm
erfec10
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
fuse box for tow bar
just fitted a 13 pin system with the bus connectors from l/r and there is a in line fuse box which holds 5 fuses,i just placed it behind the near side pannel(hope i dont need to change a fuse)..........................
It works fine,even keeps the fridge in caravan on as well as charge caravan battery.
Post #310671 Sat Aug 20 2011 2:06pm
mse
This is strange as there definitely isnt one for the 2011MY and it has the fuses in the fuse box - maybe disco and early range rover versions are different Mike
Post #310689 Sat Aug 20 2011 5:25pm
drdelrrs
I bet your problem is a poor earth, its up behind the rea n/s. Wheel remove and refit, 10mins.
Post #310691 Sat Aug 20 2011 7:09pm
