Home > Technical > stereo and sat nav turn on for 3 seconds then turns back off
sjf1
Hi all
I had a flat battery and got the AA man to come out and give my car a jump start.....but i noticed that once the car started the sat nav screen never came on and now when ever i tried turning on the stereo both the sat nav screen and stereo would briefy display for about 3 seconds then turn back off....
Any ideas
Ps the AA man said i needed a new battery as the one i have has low voltage, so i will pick one up tomorrow.
Could this be why its not turning on and is there a reset i can do?
cheers
Post #309679 Fri Aug 12 2011 8:48pm
kieltdv8
Scotland 2007 Range Rover Sport TDV8 HSE Java Black
hi sjf1
dodgy batteries cause all sorts of weird electrical gremlins
make sure your car is charging properly before you change the battery the alternators on the V8s can be a bit weak(although usually only in the winter on high load) Kiel
Post #309719 Sat Aug 13 2011 9:13am
juzi_uk
Mine does the same.. Did you get a message on the stereo saying system failure system shutting down by any chance?
Mine switches off after couple seconds and so does the sat nav... range rover vogue 2011
bentley continental ss 2011
mercedes s class 2010
Post #309867 Mon Aug 15 2011 12:33am
sjf1
Yep, found it to be a dodgy battery, once i got a new one the sat nav and stereo came back on.
Post #309875 Mon Aug 15 2011 8:06am
