![]() | Home > General > rrs key/remote and cd |
poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138 ![]() ![]() |
What do i do rrsboy? Leave key in ignition with out being turned? Or turned till lights come on dash? |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
Leave it ignition either way, how did you get on with cd player? |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
give it a good 3 hours in the ignition, with the engine running if possible/safe (if the car battery gets low, which could happen, low power mode might cut power to the key charge circuit (postulation)?). Does anyone have one of the older charging keys - can you tell us if it's Li-ion or Ni-cad charge technology? depending on the answer we will know if the battery in the key has been permanently damaged by being fully discharged. ============
Well tried that mate no good ![]() ![]() ![]() He then said a new key is on back order and i may not get one before xmas ![]() ![]() ![]() ![]() Anyway this is pi--ing me right off now only had car 2 days although i really like car apart from this issue i have. Been looking on ebay and found a blank key could this be cut at programmed at dealers even though it hasn't came from there? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEBIDX:IT |
kieltdv8 Member Since: 22 Dec 2010 Location: perth Posts: 119 ![]() ![]() ![]() |
Hi Poolie
If the fob battery is damaged/ fully discharged and not holding charge then your friendly local LR dealership can put a new battery in. IIRC they have to send them off to be done at a specialist as these fobs are like divers watches and waterproof to 300m depth (if you can find a puddle that deep!). It might even be cheaper to go to a BMW dealers as they use the same fobs in a lot of BMW's 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
