![]() | Home > Technical > Tyre change |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 ![]() ![]() ![]() |
To keep the speedo somewhere close you would need to fit 255/45r19.
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Ok thanks Andy. Merlin 1 has a set of 255 x 50 x 19 on 2010 alloys on the for sale section...will these be ok? Mine is a 58 TDV8
I should check to see if they will go over the front bremo's,im sure some 19's don't.
Ok, thanks for the advice. But they're off a 2010 RRS so are the Brembos a different size to the TDV8 ones?! So, 50 will be ok then? |
