Home > Technical > Wheel nuts
tluk
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Wheel nuts
Hi every one fairly new to the rrs only had the car 3 weeks it's a 57 plate 3.6 v8 everything appears to be fine except the wheel nuts appear to be over tight and the dealer I bought it from has just replaced rear discs and pads after a cracked disc problem 30 minutes after I took delivery of the car.
Can any one tell me what the correct torque should be for the wheel nuts as the car is going back to the garage on Tuesday for some more remedial work and I would like these setting to the correct settings, if I get a flat there is no way I can move the wheel nuts at the current pressures.
Post #308729 Fri Aug 05 2011 7:25pm
oldcro
Scotland
Can't help with your particular model, but for the MY11 RRS the torque figure for the wheel nuts is 133 Nm (98 lb.ft) according to the handbook.
check here for the 2007 model
http://topix.landrover.jlrext.com/topix/co...p;id=66046
Post #308753 Fri Aug 05 2011 9:19pm
tluk
Thanks I will look through the handbooks again os I cannot find the figure in mine.
Post #308754 Fri Aug 05 2011 10:00pm
Bobby
140 Nm or 103 lb-ft Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #308758 Fri Aug 05 2011 10:33pm
tluk
Thanks for the replies Thumbs Up
Post #308759 Fri Aug 05 2011 10:47pm
