Home > Maintenance & Modifications > Knocking suspension '06 SC - bushes vs lower suspension arm?
mrobbie
2006 Range Rover Sport Supercharged Bonatti Grey
I've been through the various knocking suspension threads, but could not see anything that tied up with what the dealer suggested.
They pointed out at the last service that front suspension bushes were starting to wear, and that I should get them replaced at the next service. They also suggested replacing the front suspension arms as these come with all the required bushes in place, so labour cost was the same but more benefit would be gained.
Can anyone suggest what this involves - parts and approx time/cost?
The car has no LR warranty and the LR dealer I visited did not point to any TSB or recalls, suggesting that worn bushes were the cause of the noise, which I guess is "wear and tear" rather than anything to shout about.
I'm fine with this, so long as it does fix the issue, but would like to know the cost and whether going to LR for the work or any other garage makes a difference.
Post #308190 Tue Aug 02 2011 8:53am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I was quoted £660 for both front lower wishbones.With a bit of thought rather than just replacing things for the sake of it and their not paying.It actually cost me 50p to stop it knocking forever Thumbs Up
Post #308208 Tue Aug 02 2011 10:14am
mrobbie
Care to elaborate on the 50p solution?
Post #308220 Tue Aug 02 2011 10:26am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
lower arms are 130 each to the trade if i remember rightly and they need to be cut off which can be time consuming. id suggest finding a local LR specialist.
Anti roll bar bushes are peanuts and worth doing at the same time.
Post #308267 Tue Aug 02 2011 11:48am
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
Why not fit the Super Pro bush kits ??
Was going to put a link up to D44 who helped develop the D3/RRS kits.............But I'm a numpty Big Cry 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #308276 Tue Aug 02 2011 11:59am
