Home > Maintenance & Modifications > SEATBELT ALARM 2011 RRS HSE |
jaxx Member Since: 13 Jun 2011 Location: Pyrenees Posts: 62 |
DOES ANYONE KNOW HOW TO SWITCH THE BEEPER OFF ?? ON THE DRIVERS SEAT
Mon Aug 01 2011 12:35pm |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 |
If anyone did know this they could make a lot of money.
Mon Aug 01 2011 12:39pm |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
same on a rrs 10y model Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Mon Aug 01 2011 2:29pm |
The belt minder function can be enabled and disabled using the driver safety belt switch. The instrument cluster changes the state of the belt minder function if, within 60 seconds of first turning the ignition switch to position II, the driver safety belt is fastened and unfastened nine times. Successful completion of the change is indicated by a single chime and the safety belt warning indicator flashing five times, at 2 Hz. Malaysia Boleh!
Mon Aug 01 2011 8:47pm |
