![]() | Home > Maintenance & Modifications > Additional 12v Sockets |
Has anyone fitted additional 12v sockets in the dash/console area of their RRS. If so where did you put them ans where did you take power from??
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
Havent done to a Sport yet but have previously put extra sockets in the cubby box with the wiring going through an existing bulkhead gromit direct to the battery (fused of course) 08 2.7 RRS "S"
Thanks - the only other place I could think of is in the ashtray area next to the one already there. However I want to use that spot for an electric trailer brake controller.
The issue is not where I take power from - it comes direct from the battery with the switching power from the brake power. The controller needs to be within arm reach of the driver so that braking effort can be adjusted as necessary for adjustments and full on brakes in emergencies when max braking effort required.
