![]() | Home > Technical > super heated rear disc- NOT usual suspects!!! |
Is there an air lock in the brake system somewhere? Have you had the brake fluid changed recently? Or it maybe a faulty brake bias valve sticking, when its jacked up it may well work fine but as soon as you put any weight on the vehicle ie back on the ground it causing the brake to come on, well thats my theory anyway |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 ![]() ![]() |
This is a new one Ady 555. Never considered a fluid problem.
I don't think there is a way to test the rear brakes only on a 4wd vehicle |
If there's nothing else I can try first, around the hardware, then I will have to get it in for LR to sort out.
If thats the case i would book it in every week in advance for 52 weeks just incase you need an appointment then cancel it at last minute if you don't |
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
Traction control issue ??? The brain may be slowing that wheel
Is there a slight judder when you apply brakes?
No judder at all and braking appears to be as pin sharp and straight as ever.
It is more than possible that a piston is sticking in the caliper, it is possible with great care to clean as much as possible with the brake system live i.e remove any rubber gaitors and pump the pistons out almost to the seals and clean the piston walls, push the pistons back in squarely and repeat. It is known for condensation to form under the gaitors causing a bit of corrosion. 08 2.7 RRS "S"
One other reason is bad driving style whereby brakes are used hard with not enough cooling time between applications for the disc to cool.
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
I've just had this issue, it's worth you jacking it up and checking the wheel bearing for play (hand top & bottom, wiggle the wheel). Initially I was convinced it was a sticking caliper, so replaced the caliper. At the same time, we noted that the wheel bearing had some play in it. A week later the superheated disc re-appeared (along with the loud thumping noise under the car at 70mph).
A number of possible causes.
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Coming back today from Nantwich to the Wirral, outside temp @23 deg C, I came down the M53 at 90mph, then onto A roads for 5 miles at 30/40mph. Got home, decided to wash the car with a hose+brush, and the front offside wheel produced steam as the water hit it. Nearside less so, but that was 5 mins later. Do these Brembo brakes produce such heat? There is no drag on the brakes as knocking it into neutral the car will roll easily! |
Yes they do, especially stopping from 90 mph ![]() Last edited by Ady 555 on Wed Jul 27 2011 11:23pm. Edited 1 time in total |
