![]() | Home > Technical > Range Rover Sport HSE and water |
buzzer Member Since: 16 Jul 2011 Location: lagos nigeria Posts: 4 ![]() ![]() |
ok, so its rainy season here, and also major floods all over. im a bit worried about taking my jeep into 2 feet of water!! ive heard that the HSE sport has so many electronic parts under the car, i fear that if i go into water, i will damage something.. Is this true? isnt the Land rover brand supposed to "fear none?" . i was in a 1970 land rover on a safari once, and we crossed a river in the jeep! now i fear i cant do it withe the HSE ! buzz |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
2ft ? Dont do it ! FF 4.4 V8 Soooo looking forward to this bad boy
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
Take it easy and you'll be fine. The door seals are particularly good in deep water (well, they are on mine!)
The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294 ![]() ![]() ![]() |
I wouldn't have thought the RRS is much different to the D3 as far as external electrics being damaged is concerned, and I waded the D3 several times. 2017 Range Rover Sport Autobiography |
First off - it isnt a Jeep and usually on any Land Rover forum or group, reference to Jeeps is considered swearing...thats usually defining a defender as a jeep any range rover - well thats an insult ![]() Anyway - far to many factors to consider with water crossings and if you havent ever played with water then i suggest you dont start in a Range Rover. 2ft, 1ft whatever, it can just as easily be done as not be done. Electronic equipment is reasonably robust and sealed to withstand the wading depth LR set - get to know this and what it looks like. However, there are other factors - river flow, surface, hidden obsticals, bow waves, exit vehicle height etc - If you dont know the factors involved with rivers flow and your car floating (yes they do, a downside to good door seals) learn it, before you try and try killing yourself and passengers, not to mention writing off you sport. Water and any car just doesnt mix - im not being a kill joy, ive had water over 3/4 up the windscreen of my discovery (for a foot or two) and played in a lot of it - just about safely. Im also fully aware i dont know it all and its a fine line between my skill avaliable being short of required skill. A friend, who i consider as much more competant and capable than me off road etc came stuck when his 110 on a simple ford introduced its self to the bridge - a simple crossing became full on rescue - car secure, next day extraction and write off. Be careful and learn the skills. Mike 2014 Facelift Discovery |
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
MSE...good post |
Thanks Mike 2014 Facelift Discovery |
MikeS's post is spot on; you'll note his photo is with the flow head on. If this was sideways the RRS would be travelling with the flow and, if the floor of the stream had and lumps, ridges or obstructions the RRS would probably tip over.
Sorry earlier post was referring to Mike, as in mse's post - too many Mike's too early on a Sunday. |
Wow! great information, thanks all... the picture of that range in the water is fantastic for an advert... i wouldnt risk mine though, not enough service centres here.
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
Theres a ford in Wales that sounds just like that ! 08 2.7 RRS "S"
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
more people on here with more experience than me when off roading but i believe 700mm is the RRS max
sunseeker Member Since: 10 Sep 2011 Location: England Posts: 43 ![]() ![]() ![]() |
brave! Oh wow |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
No this is brave |
