![]() | Home > Technical > Poor handling in the wet |
It all depends on what tyres you have on your vehicle, my guess is that they are summer tyres, It doesn't help that we havn't had much rain for a while now but when it rains after a long dry spell the roads are very greasey due to all the oil/diesel spillages from other vehicles, |
Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30 ![]() ![]() ![]() |
I have pirelli scoropin zero's on 285/35/22. This is not the first time I have had this experience as it seems to be every time it rains. I just thought the the handling for some reason would be better than this! |
get your tracking checked |
Scary was exactly how I would describe it at the moment! |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
I have 22s with toyo proxes and drove 300 miles back from the golf yesterday in awful weather, no problem at all, steady as a rock. |
In a straight line ![]() |
chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123 ![]() ![]() ![]() |
It isn't something as daft as a spotty trainee tyre fitter putting them on the wrong way round and/or on the wrong side is it? Ive known it happen before. |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
tyre pressures make a huge difference in the wet.
edvarski Member Since: 08 Feb 2011 Location: Knaresborough Posts: 19 ![]() ![]() ![]() |
The other option is to change the driving mode button from normal to snow/grass setting. It sets the car up so that it is less likely to get pulled to the side if you hit standing water.
Just found out that a wheel bearing needs replacing so not sure if that has anything ot do with it but once that is fixed I will see about having the wheel alignment checked, if I can find anywhere is Sussex that will do 22 inch wheels!
