Home > Technical > Parking Assist problem
THE VOICE
2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi I have just joined this Forum with the hope that someone can assist me. I have a 2005 (sept) 2.7 HSE RRS and the interior dash light for parking assist is flashing all the time (unless i turn it off) The parking sensor does not work any more since the light stated flashing (before the light started to flash I had a higher pitch tone when parking, but at least the assist did work) I booked the car in to land Rover and they confirmed that after all tests that the module was to fault.(sensors OK) (the module in the car is YWC 500312. I ordered a new module and fitted it but the problem still exists (park assist does not work and light still flashing) Does the new module have to be set via a computer?? Is there a trick or method of installing the module that requires a "reset" ?? If it should work could I have maybe the wrong module? RRS 2.7 diesel 09/2005
(Landrover said it should be the module YWC 500730?? but thats not the one in my car and is there a difference anyway) Thanks for any help
Post #305548 Fri Jul 08 2011 3:44pm
Simply get the dealer to fix - it actually sounds more like a faulty sensor than a module . 2005 Zambezi TDV6 - Gone but not forgotten
Post #305558 Fri Jul 08 2011 5:49pm
airwolf222helicopters
parking sensors has to be reset via computer
dealer trip Thumbs Up
Post #305559 Fri Jul 08 2011 5:52pm
THE VOICE
Thanks . So as you wrote it could be the case with my problem. Fitted the new sensor but still have to get the garage to reset the sensors?? Dam wanted to avoid another cost Thanks
Post #305645 Sat Jul 09 2011 10:02am
Bobby
The parking aid module has a diagnostic connection via the medium speed CAN to enable faults to be retrieved using a Land Rover approved diagnostic system. Additionally, an on-board diagnostic routine within the parking aid module constantly monitors the system and alerts the driver to a system fault by emitting a tone from the front or rear sounder, depending on the fault.
If a parking aid system fault has occurred, the parking aid module will relay the occurrence of the fault to the driver in the following ways:
The status LED will flash at a frequency of 2Hz if the system is active and fault is detected in the sensors, sounders, related wiring or the module.
The front sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the front sensors or the rear sounder develops a fault.
The rear sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the rear sensors, the switch, the LED in the switch or if there is a CAN bus error.
New parking sensors do not need to be reset via any computer. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #305647 Sat Jul 09 2011 10:15am
THE VOICE
Thanks for your info BOBBY.. I was told by the Land Rover dealer that my MODULE was faulty and sensor were OK!!(sorry wrote sensor on my last mail, meant to write fitted new module) I fitted the new module only to find that I had the same problem, no parking assist and light flashing. I was wondering if after fitting the new module that the system had to be reset via land Rover??? or they did not correctly diagnose the problem ?? ..Thanks
Post #305655 Sat Jul 09 2011 12:35pm
Bobby
There was a revised module for the earlier cars and no, no need to reset anything.
Can you not identify the problem with the information provided? Malaysia Boleh!
Post #305657 Sat Jul 09 2011 12:44pm
buzzer
2009 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Can i retrofit reverse cameras on my 2009 Sport HSE?
I have a 2009 Sport HSE, and im surprised it doesnt have any reverse cameras! they have been installed in much cheaper cars for years, Now i see that Range Rover have added cameras all around the 2011 models! Can i fit cameras on my 2009? Can i change the whole entertainment system? My satnav also does not function, due to the region im in, is there a DVD that can change the satnav settings? buzz
Post #306356 Sat Jul 16 2011 11:25am
