Home > Technical > Flat battery |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
Check the cables/connections and earth first mate. Common cause and often missed ending up costing people a fortune for no reason. |
Tue Jul 12 2011 5:23pm |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
All the connections on the battery are in tip top nick No corrosion and all tight. Not sure where earth is bolted to? SDV8 vogue SE. Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
Tue Jul 12 2011 6:58pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
check your upper tailgate relies switch had the same on mine took me 3 weeks of testing to find the problem god knows how much it would have cost in the dealers to find the problem they tend to corrode inside take the outer rubber casing off if its corroded inside thats your problem m8 do a search on the forum battery drain and it will tell you everything you need to know about it |
Tue Jul 12 2011 7:18pm |
Baxc Had trouble opening the upper part recently. Where abouts is it SDV8 vogue SE. Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
Tue Jul 12 2011 8:44pm |
OK. Battery drain. I will go look SDV8 vogue SE.
Tue Jul 12 2011 8:52pm |
Sure enough once the rubber cover was removed total corrosion evident. New unit fitted by dealer.
Thu Jul 14 2011 9:20pm |
hope it cures your problem m8 let us know how you get on |
Fri Jul 15 2011 6:17am |
Car back from dealer. Bill £78. Part was cheaper than E bay item posted I left car at dealers for 36 hours and started with no fuss.
Fri Jul 15 2011 10:11pm |
Got back from west country last night after a week away and car started this morning no problem.
Sat Jul 23 2011 2:16pm |
no probs m8 |
Sat Jul 23 2011 4:19pm |
no probs m8 |
Sat Jul 23 2011 4:20pm |
