Home > Maintenance & Modifications > Oil top up question
bunnyman
Oil top up question
Hi all,
I got my new MY2011 3.0 TDV6 HSE in March and have so far covered 4k miles. Checking the engine oil level via the OBC it appears I still have nearly 3/4 oil left and no need to top up as yet. This has surprised me so I was wondering if this was both normal and accurate!?
Assuming I will have to top up at some point can anybody recommened a good online site to buy the right engine oil?
Cheers.
Post #304895 Mon Jul 04 2011 9:36am
mse
A few searches would yeild your results.
Accuracy - its apparently reasonably accurate...there isnt any other way to check it so ermmm you need to rely on it (and be accurate yourself)
You will struggle to buy the oil from anywhere as its a special spec (no not viscosity eg 5w40) - your only options are a dealer (Jag or LR) and get the correct make or opie-oils and get the incorrect brand but still the right spec
Finally if you read the hand book it will tell you about topping up the oil - the display tells you how much to add, which i deduced makes it bloody hard to guess how much to put in. Mines been on 3/4 since the second day of having it...must check it again actually - it can be a pain not having a dipstick
hope that helps Mike
2014 Facelift Discovery
Post #304911 Mon Jul 04 2011 12:02pm
Portman Len
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I also picked up a new 2011 MY Sport in March, and at hand-over, my dealer advised me that I shouldn't need to top-up oil in between services....
Just checked, and I am three-quarters full so sounds about right.
Cheers,
Post #304912 Mon Jul 04 2011 12:30pm
mse
Cheers,
Very niave thing for a dealer to say, especially on a new car and given the handbook say almost the opposite!
I try not to listen to dealers anyway Thumbs Up Mike
Post #304916 Mon Jul 04 2011 12:57pm
Portman Len
Cheers,
I did think that at the time, but who am I to question. Next time I'm at the dealership I may buy a litre just to be on the safe side though...
Seem to recall that somehwere on the engine bay it states the recommended oil (I'm sure it's Castrol) but a quick search on Castrol's own website refers you back to the main dealer!
Post #304922 Mon Jul 04 2011 1:15pm
mse
Portman Len wrote:
Cheers,
Do a search on here and/or read you manual - the correct spec is in there. You will not be able to buy it retail on the high street or from a trade motorfactors when in the trade as i found out!
Apparently buying the oil is cheaper at a jag dealer than an LR one - but then the dealer just gave me the oil. Mike
Post #304924 Mon Jul 04 2011 1:28pm
oldcro
Scotland
Check here http://www.opieoils.co.uk/p-68975-shell-he...e-oil.aspx
for the correct oil spec.
I've only done 2,400 miles and the oil level has not moved below 3/4 full since new. When checking the oil level make sure engine is up to temperature and wait 15 minutes. Check again after another 5 minutes and if level is higher repeat again after another 5 minutes until level stabilises.
Synthetic oils expand a lot more than mineral oils when hot, so checking with engine cold may show say 1/4 level and topping up to say 3/4 level will overfill the engine.
Post #304962 Mon Jul 04 2011 5:22pm
shepp
check my sc regular for oil consumption, , ive never had to top it up, either it barely uses any oil at all, or it suffers water dilution through condensation, which is the most common
ive had manny japaneese cars that have used up to 1/2 litre every 1000 miles, but they were desinged that way.
Post #304965 Mon Jul 04 2011 5:31pm
