Home > General > crazy temp gauge
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
crazy temp gauge
Odd one.. driving around all day yesterday in the 31c heat, air con on full – temp gauge didn’t budge. Went to the car wash I always go to. Had to stop about 30 seconds later to rescue my Defender (whose fuel line had burst.. another story!) and happened to park the RRS on a steep incline (facing up) for about 3 minutes. When I got back in and drove off, car was in low power mode with the warning “car overheating” and the temp gauge at maximum! Immediately pulled over and relieved to see that 1. engine fan was running 2. coolant still intact and not boiling. Temperature gauge very quickly normalised. About 2 miles later, start driving up a relatively steep hill, temp gauge goes to maximum again! On the flat at the top, back to normal quicker than it could possibly cool if it were actually overheating. So my suspicion of course is that water from the car wash (enthusiastic with the power washer?) has got into a sensor somewhere.
Question is – what sensor, where and will it dry out or will I need to replace?
Drove 150 miles in the evening on the relatively flat motorway without incident and without the temp gauge moving from middle i.e. normal. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #304069 Mon Jun 27 2011 8:28am
i had similar to what your describing on my old FL2, driving along the car was fine towing the caravan, hit traffic and the car temp gauge bounced to max and back again within minutes
LRA came out, levels in system all ok and no faults logged, no boiling water etc
10 days in dealer and they came back, when taking the rads out to have them flow checked, that the lower section was clogged with mud, and they decided to wash this out and put it back together
Might be worth a check on yours if used off road Idea
Now my mud had been there for 18 months without issue, so I got the £4 water temp sensor replaced myself as LRCS insisted that could be the cause
Either way, the sensor or the mud was the cause as it never happened again
Post #304077 Mon Jun 27 2011 9:46am
rrsboy
interesting - thanks for the info. This one hasn't been off road so I don't think it's mud blockage. Bobby - can you shed any light on vulnerable sensors that could have got water soaked, and caused this to happen? ============
Post #304145 Mon Jun 27 2011 6:33pm
rrsboy
local Landy garage say the only sensor that could be affected in this way is the ambient temperature sensor, which is in the front bumper. Not overly convinced tbh! ============
Post #304262 Tue Jun 28 2011 11:42am
Bobby
ECT Sensor for an earlier model... should be the same.
Check the wiring/connectors too.
Did any diagnostic trouble code appear? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #304366 Wed Jun 29 2011 5:26am
rrsboy
many thanks Bobby - getting the codes read today to see if anything was logged Thumbs Up
Post #304386 Wed Jun 29 2011 9:17am
rrsboy
no codes Sad ============
Post #304432 Wed Jun 29 2011 2:13pm
Just been having a search for similar issues on Disco3, Thumbs Up
http://www.disco3.co.uk/forum/topic50744.html
Post #304437 Wed Jun 29 2011 2:39pm
rrsboy
thanks - because it's only happened once, and because that was immediately after a high pressure wash, and because it was then fine for a 150 mile motorway journey, i am more inclined to think some water penetrated (somehow?!) as opposed to sensor split or completely broken. But looking where the sensor is, it's hard to understand how water could have got to it such a way as to then only cause an issue when going up a hill?! Censored Censored ============
Post #304442 Wed Jun 29 2011 2:57pm
