Home > General > Dynamic Response & Adaptive Dynamic
JacekM
Poland
I have just ordered RRSport (TDV6 HSE) - the 2012MY with 8-speed ZF. Since it's a european version it does not have Dynamic Response & Adaptive Dynamic included (as it is for UK HSE versions). Still have around 4 weeks to modify the order. I obviously know what these systems are responsible for, but keen to listen to your thoughts whether it's worth paying extra money for it or not? Do you feel much difference when driving the car having these systems enabled?
Your comments will be appreciated
Jacek
Post #303947 Sat Jun 25 2011 10:51am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
IMHO I think the Dynamic response is well worth it. If youre going to throw the car around or if you live near narrow country roads.
The drive is a lot more trustworthy and feels like the whole car stiffens up and just is tighter around corners.
I would be interested to know what other features youve gone for.
Foxy ! Thumbs Up Smile
Post #303970 Sat Jun 25 2011 5:48pm
mse
It is a great system to have...i didnt realise it wasnt standard - its supposed to be another differentiation between disco and rrs Mike
2014 Facelift Discovery
Post #303971 Sat Jun 25 2011 5:49pm
Bobby
Dynamic Response has been with the RRS from day one, although it may be an optional item in some markets.
The Dynamic Response system provides improved vehicle handling and ride characteristics and is active for both on and off-road driving.
The Dynamic Response system uses two accelerometers to detect vehicle cornering forces and inputs from the steering angle sensor to supply data to a dynamic response control module. The control module then operates solenoid valves in a valve block which apply hydraulic pressure to actuators fitted to the front and rear stabilizer bars. The application of hydraulic pressure to the actuators applies a specified amount of torque to the stabilizer bars to counteract the cornering forces and minimize vehicle body roll.
Adaptive Dynamics is quite new and it is actually "continuously variable damping".
Adaptive dynamics is an electronically controlled suspension system which continuously adjusts the
damping characteristics of the suspension dampers in reaction to the current driving conditions.
The system is controlled by an Adaptive Damping Module (ADM). The ADM receives signals from three accelerometers, four suspension height sensors and from other vehicle systems to determine
vehicle state, body and wheel motions and driver inputs. These signals are used by the ADM to continuously control the damping characteristics of each damper to the appropriate level resulting in optimum body control and vehicle ride.
I would say, go for both! Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #303993 Sat Jun 25 2011 9:19pm
JacekM
Poland
1. I thought that RSC (Roll Stability Control) was supposed to be counteracting the cornering forces and minimizing the risk of vehicle body roll?
2. Driving on motorways (and being not very aggressive driver) will I really feel the difference having these systems in place?
They don't cost that much comparing to the vehicle price (both around 2000 GBP), just want to make sure this money would be well spent on
Thanks!
Post #304061 Mon Jun 27 2011 7:18am
Bobby
Yes, that's what I said above. Only its called "Dynamic Response" as in your first post! Wink
You'll regret someday if you do not get it now!! Laughing Malaysia Boleh!
Post #304063 Mon Jun 27 2011 7:34am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
D.R makes the car, A.D is the cherry on the icing on the cake. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #304068 Mon Jun 27 2011 8:20am
