Home > For Sale & Wanted > Rubber Mats - NOW SOLD
simon1233
Dear All
As I have now sold my sport I have some bits for sale, I have a set of unused range rover rubber mats. Definitely fit earlier models, not sure about later models.
£45 + £10 for 24hour courier delivery
Or come and collect
Post #303828 Fri Jun 24 2011 4:34am
simon1233
bump Whistle
Post #308357 Tue Aug 02 2011 7:49pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Would they fit a 58 plater - with the single hook/hole?
Post #308388 Tue Aug 02 2011 10:17pm
simon1233
Hi PeanutBob
They would need to use the fittings that are provided with them, as you can see in the photo below the mats have 2 retention points in each of them. These screw into the carpet and then the mats locate onto them.
The mats should be the correct shape and size for your car, but the hooks are different.
Post #308469 Wed Aug 03 2011 12:49pm
simon1233
Just had a look at the mats and I think they would fit a 58 plate car with a single central hook fitting. If you look on the photo you can see there is a rubber disk in the appropriate area of the front mats, this is a bung and can be removed - I assume to allow you to use the later type single hook retainer.
The top of the bung is about the size of a 10p piece, the hole it covers is probably slightly less than a 5p piece in diameter Thumbs Up
Post #308507 Wed Aug 03 2011 7:07pm
simon1233
Bump Whistle
Post #312702 Tue Sep 06 2011 6:34pm
