Home > Technical > GPS "not a DVD map inserted" message
fredouille
France 2005 Range Rover Sport TDV6 HSE Java Black
hi everyone, to share my experience, hope this will help.
I have a 2005 HSE Range Rover Sport with a faulty GPS navigation.
after several research, clean/change the DVD disc, check connectors, clean the lens, it sounds like it comes from the optical laser unit of the DENSO GPS ECU DVD drive (which is a DVS-3011).
- a brand new ECU is very expensive at dealer (1000 euros)
- a used one is around 400 euros... without any idea of cyclelife ahead...
- the laser unit optical lens reference is "Sanyo SF-HD4 with white cap" and it can be found on ebay for 20euros...
it is tough to disassemble the dvd drive; i did, so I'm looking forward receiving the laser unit and check if this fix is the cheapest I found!!!
stay tuned...
fredouille
Post #301869 Sun Jun 05 2011 11:01am
Bradders
Bien fait, Fredouille.
Faites-nous savoir si vous le réparer! Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #301874 Sun Jun 05 2011 11:35am
ChrisP
I always wondered what "It's f Censored d" was in French Rolling with laughter ! MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #301879 Sun Jun 05 2011 1:01pm
mse
Re: GPS "not a data disk inserted" message
stay tuned...
fredouille
Depends how good you are at that stuff.
Ive replaced components on TV's, Stereos etc - if you know what the fault is and half compentent with a soldering iron etc you should be good. Mike
2014 Facelift Discovery
Post #301883 Sun Jun 05 2011 1:55pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Aye up tord fella a bit posh, i bet you eat them cross ants as well!
Post #303264 Sat Jun 18 2011 11:01am
fredouille
ouch....
did replace the laser lens unit... same thing... Embarassed
"not a dvd map inserted"... comes from somewhere else...
still the cheapest (non) working fix ever .... Neutral
Post #303694 Wed Jun 22 2011 8:47pm
flydive
Are you using the original disk or your back up? '08 RRS TDV8
Post #303696 Wed Jun 22 2011 8:51pm
fredouille
actually tried both...
also tried other versions "from web" without success...
that is the reason why i was thinking it comes from hardware...
Post #303697 Wed Jun 22 2011 8:53pm
