![]() | Home > General > Annoying front wheel tapping noise |
a tap tap tap from a wheel that is speed sensitive...
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Exactly what i was thinking 2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Try swapping your wheel round with the back one, or check the inside of your front tyre |
kupid0n Member Since: 26 Jun 2010 Location: oradea Posts: 30 ![]() ![]() ![]() |
had the same problem with my dad's landcruiser last week....worn brake pads caused it.....but again....it could be a number of things, except the bearing....because then you would hear a continuous rubbing-like noise |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
[quote="awd man"]a tap tap tap from a wheel that is speed sensitive...
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Doesn't sound like a ball joint to me,as others have said stone or nail,also check your disc /pads for a stone my brother had this on his TT the other week,If you do go the ball joint route I have a spare front lower here.I ended up buying 3(don't ask) |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Marc31 Member Since: 04 Mar 2008 Location: Lancashire Posts: 73 ![]() ![]() |
Thanks for the constructive replies folks and thanks to Mrfixit especially.
