Home > Technical > RRS goes up 55mm D3 goes up 100mm ? how come ?
riverblanche
Hi, am i right in understanding that the RRS raises about 55mm from standard height to full off road height,
yet the D3 raises about 100mm?
that will limit my green laning.... Cool
Thought they used the same suspension/air bags?
Got throught about 5 pages of the tech forum and saw it went on to 51 pages, so can i ask first rather than paging through them Whistle
is the suspension different
or can anything be over ridden?
ta. Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #303028 Wed Jun 15 2011 11:11pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
No, they raise pretty much the same - the D3 figure you are quoting is the height difference between on-road and emergency height, which is the same for the RRS.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #303030 Thu Jun 16 2011 12:13am
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Okay....someone has to ask...................... what is 'Emergency Height and how/when is it activated? Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #303033 Thu Jun 16 2011 5:22am
flydive
Extended eight(emergency) gets activated automatically when the car senses it has bottomed out. '08 RRS TDV8
Post #303038 Thu Jun 16 2011 7:33am
DrLex
Iceland
The standard off-road clearance for a D3/D4 is approx 240mm; for the RRS it is 225mm; for the RR it is 280mm. These figures are averaged from a number of vehicles of each make.
The "310mm" figure is the maximum height you can attain with a D3/4 (emergency extended height). It's a marketing ploy by LR to quote this figure for the Discovery. Apparently RRS owners don't care.
The difference between the RRS and D4 is only some 15mm, most of that is due to the slightly smaller tyres fitted as standard (12mm smaller radius). If you fit the same tyres as the Disco, you basically have the same height and a better ramp-over angle due to the shorter wheelbase. This makes the RRS slightly more maneuverable off-road than the Disco. However, don't be surprised if on an LRE course, you don't do exactly the same tracks in an RRS as in a D3.
Post #303046 Thu Jun 16 2011 9:18am
riverblanche
Hi All..
thanks for that it sounded like the D3 would have more clearance, I just could not work out how ?
Like a lot of thinks to do with figures it depends what answer you want first, then use figures that give you that answer Exclamation
Been for a test drive in a RRS today and while trying the access: standard: then off road, found it only went down to access and back to standard ok but going up to off raod got a message "slow to raise", suspect this is a compressor starting to show a fault, dealer (indep) said he knew there was nothing wrong with it Confused
Have walked away, still looking. Porsche Cayenne 2022
Post #303095 Thu Jun 16 2011 6:24pm
