Home > Technical > Whining on tick over and low revs
jetblasters
2005 Range Rover Sport TDV6 Java Black
Hope everyone is well. Yet again I ask for your advice/suggestions.
I have a 2005 RRS Diesel and touch wood other than the three amber lights and two dongs from the system issue (HDC issues) I haven't had any cause of problem with my car, however, this morning I noticed a noise I haven't heard before, it's a whine which you can hear on tick over or low revs (as the noise of the engine masks the noise over 2,500rpm). It's not the turbo I think as this sounds/acts as normal. On idle if you tap the accelerator the whine increase and then decreases as the engine comes back to idle/700rpm.
Anyone have any ideas? I don't like the idea of sending to the dealer unknowing what the issue may be.
Cheers,
Stuart
Post #301942 Sun Jun 05 2011 8:16pm
What is the cars mileage? At first guess i would suspect alternator or one of the belts are slack or worn.
Ady
Post #301944 Sun Jun 05 2011 8:23pm
jetblasters
98,000 miles sir. No electrical power issues, not running in low power mode or anything. . .
Post #301945 Sun Jun 05 2011 8:30pm
Texstar
Along with alternator or belt, check the belt tensioners too, upper and lower, the bearing in the lower one tends to take more of a hammering, and can fail at that mileage. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #301947 Sun Jun 05 2011 8:45pm
Can you identify if it coming from the back or front of the engine? Its almost due for its belts changing anyway Big Cry
Post #301948 Sun Jun 05 2011 8:46pm
jetblasters
I think the whine is coming from the front, just started up to check and got a whiff of something like brake linings, saying that I don't make a habit of sniffing under the bonnet on startup! Wink
Thanks for the advice thus far, will get the car booked in at the garage.
Stuart
Post #301955 Sun Jun 05 2011 9:37pm
