Home > Technical > 2008 to 2011 adaptive lights - WILL IT WORK?
jundrill
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
I am looking to facelift my 2008 Range Rover Sport HSE (V8 3.6) to the 2011 front and rear (new lights, bumpers etc).
I can't foresee any issues bar the front lights I currently have are the adaptive ones so they move as I turn corners - now I'll order the same adaptive lights off the 2011 model but will they work once installed? I.e. will my 2008 computer be able to talk to the 2011 lights and thus the adaptive lights will still work? Will I get any warnings?
Thanks all,
Jon
Post #301229 Mon May 30 2011 2:42pm
Is it really worth all the expense? Oh and don't forget the front wings Wink Then there is your insurance company Rolling Eyes Sorry i can't help you with your question, but i will be very surprised if its a straight swap.
Post #301231 Mon May 30 2011 3:16pm
jundrill
Someone must know?
Post #301239 Mon May 30 2011 4:32pm
kahndesign
you can change the car to 2011 spec and kee your adaptive headlights.
parts you will need are as follows
2011 speec adaptive headlights
2011 front wings
2011 front grille
2011 side vents
2011 front bumper
wiring harness
bumper brackets
parking sensors (theyre a different size)
not a cheap job but it does look awesome when done correctly
hope this helps
martin
Post #301316 Tue May 31 2011 9:59am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Will this work affect the warranty?
(I am feeling like the warranty queen).
xFoxy Smile
Post #301326 Tue May 31 2011 11:11am
kahndesign
not too sure foxy,
the parts we use are all OEM ones so i would need to check.
my guess is that any car thats wanting to undergo a facelift conversion is outside the LR warranty period anyways.
martin
Post #301330 Tue May 31 2011 11:45am
RRS PIMP
why does the wiring harness need to be changed?
Post #301372 Tue May 31 2011 3:51pm
jundrill
RRS PIMP did you just plug the new lights straight in (part numbers: LR023558/57) and they worked with no issue? No dashboard error lights etc and you didn't have to adjust the wiring looms or install resisters etc?
Thanks all,
Jon
Post #301508 Wed Jun 01 2011 2:51pm
ilard
Re: 2008 to 2011 adaptive lights - WILL IT WORK?
Just this one Rolling Eyes
I just prefer the un-Gigged RRS's is all! Makes me a bit of an old crusty Very Happy L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #301688 Thu Jun 02 2011 9:35pm
jundrill
ilard so you've converted too using those part numbers and you had no issues at all?
Post #301719 Fri Jun 03 2011 7:18am
ilard
No, I'm factory standard. Most people I know prefer RRS's factory standard. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #301721 Fri Jun 03 2011 7:22am
SRE
Spain
The only way I think an update like this should be considered is if you had a front end shunt, such as Geoff did on the Disco 3 forum http://www.disco3.co.uk/forum/topic65893.html?highlight=
Better bet, save your hard earned, and buy a lter model in a year or so. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #301730 Fri Jun 03 2011 9:30am
jundrill
SRE, that is my reason!!
Post #301747 Fri Jun 03 2011 2:28pm
0cj0
Pm sent Thumbs Up
Post #301749 Fri Jun 03 2011 2:40pm
SRE
Spain
Get some photos posted, then we will be able to see the before and after. Thumbs Up
Syd In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #301754 Fri Jun 03 2011 3:24pm
