Home > Technical > Brake light bulb replacement ???? |
Not knowing the age of yours - but knowing the light cluster changes dont really matter...its easy!
Thu May 26 2011 6:47am |
Jimmy07 Member Since: 01 Apr 2011 Location: Southyorkshire Posts: 62 |
Hi thanks or info pal it's a 07 took screws out
Sat May 28 2011 7:25am |
Someone with an 07 im sure will be along to confirm but im sure they are the same.
Sat May 28 2011 7:33am |
Southern Jock Member Since: 02 Nov 2010 Location: Newbury Posts: 69 |
Ive got an 08.
Sat May 28 2011 7:55am |
Right thanks will do I'll give a try tomoz do u no if the brake stop and brake side light or same bulb as it's the brake stop on passenger side that needs replacing ?? |
Sun May 29 2011 5:57pm |
