Home > Technical > I pod I phone aux connection
Jimmy07
United Kingdom 2007 Range Rover Sport TDV6 HSE Bonatti Grey
Hi I'm wanting to connect me iPhone 4 s iPod to the standed stereo is the best way to do this with a lead to the aux plug in the bk ?? And what kind of lead do I need ????
Post #300417 Mon May 23 2011 2:32pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
you just need a standard lead that plugs into the headphone socket..needs to be same at both ends...get one that is retractable ..easier to tuck it away than a standard size lead
Post #300419 Mon May 23 2011 2:38pm
Jimmy07
Oh right thanks what is the correct name for this lead so can search for one on eBay??
And what are the retractable ones not seen them ???
So am I right in thinking that it's just connected by he aux in the bk of the rrs and the head phone socket in iPhone 4 and not the charger slot ??
Post #300431 Mon May 23 2011 5:10pm
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
I wouldn't bother. you can hardly hear it as the aux input doesn't go through the amp.
Post #300432 Mon May 23 2011 5:19pm
ronniet101
interesting mine seems to work and its plenty loud enough
Post #300433 Mon May 23 2011 5:20pm
felstmiester
When you say its plenty loud enough if the full volume on the stereo is 35, what would you say the volume is when plugged into aux?? Maybe there's something wrong with mine. I would say mine is half the normal volume.
Post #300443 Mon May 23 2011 6:08pm
ronniet101
just tried it and its about 5 units lower than the radio...you can adjust volume using the ipod/iphone volume setting and by using the amp in the car
Post #300444 Mon May 23 2011 6:20pm
ronniet101
dont know if it matters if your car has rear seat entertainment system or not...mine does and it uses the cars amplifier if it didnt when you turn volume control up you wouldnt hear anything
Post #300445 Mon May 23 2011 6:22pm
simon1233
Aux input does go through the amp, but is controlled to be at a lower level. I would prefer that it was louder, but assume they have done this to allow for a wide variation in the volume of the input device. You'd be pretty mad if you managed to blow the amplifier by having an input that was too loud
Post #300450 Mon May 23 2011 6:50pm
felstmiester
well mine deff isn't worth plugging in. I have tried different leads with mine, messed around with the volume settings on my iphone and i've even tried the wifes iphone incase mine was on the blink but nothing makes it loud enough to listen to it above half volume. mind you!!! If i have the phone plugged into aux and it rings, thats loud!
Post #300463 Mon May 23 2011 7:46pm
simon1233
felstmeister, have you tried a lead that goes from the dock connector to a 3.5 jack? This is the loudest output you can get from an iPhone/iPod etc?
I find that I am now just making data disks with 10 albums per disk at least, saves messing with the wires etc.
Post #300465 Mon May 23 2011 7:52pm
felstmiester
yeah, another forum member sugested that when i first brought the subject up. I brought one but it didn't make any difference. Oh well!! Start burning some cd's Rolling Eyes
Post #300467 Mon May 23 2011 7:57pm
simon1233
Make sure that you only burn MP3's to the disk, car won't recognise anything that is AAC (tracks bought from iTunes), iTunes will convert any AAC tracks to MP3 for you though.
You can burn a playlist from iTunes as a data cd but then you end up with one folder and hundreds of tracks. I found it easier to create folders outside of iTunes (1 per album) and then burn the data disk with the folder structure. The car then recognises the folders which makes navigation a little easier
Post #300471 Mon May 23 2011 8:07pm
Jimmy07
What's the name of the lead I need ???
Post #300482 Mon May 23 2011 8:33pm
felstmiester
3.5 to 3.5 Jack lead or iphone to 3.5 jack.
Post #300639 Tue May 24 2011 7:05pm
