![]() | Home > Australia & New Zealand > maximum tyre sizes, LLams and Johnson Rods combo |
Jimmy Salsa Member Since: 03 Mar 2009 Location: Hunter Valley Posts: 257 ![]() ![]() |
I know that offroad tyres are the bane of a Sport owners existence and I for one am still struggling to get satisfactory mud profile rubber under the guards.
Hi Gordon
Run the Llams setting at -20mm for on-road use (giving you a +30mm at all times) Run the Llams in the off setting for general off-road use Run the Llams at +30 or +50 manually as the terrain requires it. Hope this makes sense to someone else out there. 'Black Betty' Java Black RRS 07 TDV6 |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
Your explanation of the extended mode is not quite right.
Thanks for clearing that up Gordon.
Jimmy - ask Gordon about the new product to get around this issue that he is developing |
It depends on what level of fault you're experiencing. A single ABS or transmission fault may drop the car to access height, in which case either the rods or LLAMS will give you the ability to raise the car to at least on-road height. However, most faults with the EAS itself (compressor, height sensors, valve block, leaks etc) will drop the car to the bump-stops. That is, the system is completely disabled, and no amount of sensor trickery (rods or LLAMS) will recover it. I'm working on a solution for this, PM/email me if you want more info. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Gordon, JS, a question for a novice here, i have the standard 19' V Offroad Alloys on my TDv6 3 litre, what tyres with more off road bias would fit as standard without the need for any hacking of the liners or potential rubbing. Are there any that meet the load and speed ratings, as none of the tyre company websites or distributors suggest any do.
Hey Zilch,
If you're sticking to your 19" rims, you only have two options, the Pirelli ATR or the General Grabber AT. The latter is not available in Oz yet (2 to 3 weeks before the first shipment arrives) and the former can be pricey and difficult to locate. Both will meet the vehicle specs and provide better off-road/touring performance than the std road tyres.
Gordon, JS, thanks for the advise, i may wait for the GG's to arrive and see how quickly i can swap out the eagles |
raadar Member Since: 07 Oct 2010 Location: sunshinecoastQ Posts: 38 ![]() ![]() |
hi zilch
frank, main issue i have is that i have nowhere to store them, my house in Airlie is a holiday let, so no room there and i have an apartment in Sydney with no secure storage (apart from a vehicle space). Hence the reason why i am thinking of the tyre replacement route. I would love a set of the compomotives, but same problem |
I wonder how much helium is needed in each tyre to get them to float on the ceiling??? LOL my10D4se3Ltdv6 current
Hi Zilch,
