![]() | Home > General > Extended warranty |
Do you like to sleep at night |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Wouldn't dream of running a LR product without a warranty, they are just too unreliable! For me it's a case of getting the best warranty I can for reasonable dosh (not necessarily cheapest), they can be the automotive equivalent of the film "The Money Pit". The present D3 is the last LR product I'll be buying as a main family car, by the time I work my way around the other manufacturers I'll be too senile to drive. That's a big change as the last 5 main family cars have been LRs (3 x D3s, a D2 and a 90) but you reach the point of having had enough, it is just a never ending stream of problems. |
GTSteve Member Since: 20 Dec 2010 Location: northamptonshire Posts: 38 ![]() ![]() ![]() |
If I were you I would definatly get a warranty! mine ran out in March so took out an extended Warranty and just as I expected the car develeped a fault last week (Air Flow Meter) would have set me back over £400, these cars arn't cheap when they go wrong. BLACK RRS HST 3.6 MY08 |
Some people over play problems and reliability - any forum, such as this, will flag problems as thats there point! but many many many other cars have problems - compare that to the number sold the failure or issue % is low and no better or worse than other cars in the main...premium or otherwise.
raadar Member Since: 07 Oct 2010 Location: sunshinecoastQ Posts: 38 ![]() ![]() |
if you were to ask "murphy" he would advise that if you get the warranty you won't need it and if you don't get the warranty you will wish you had done so. My advice is that you had obviously budgeted for a replacement vehicle which now will not be required, therefore you should allocate a small amount of that budget to add value and security to the vehicle you have decided to keep.
