Home > General > Reseting the Service display
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Does any one now if the service light/reminder can be reset its on a 2006 RRs its reading "service 30"????????
Post #298087 Wed May 04 2011 4:51pm
Warren G
The procedures described below are relevant to the following European specification models:
Model Chassis Model year
Discovery 3 / LR3 L319 2005 to 2006
Range Rover L322 2002 to 2004
Range Rover Sport (not supercharged) L320 2005 to 2006
1) Procedure to check/reset service status – Distance counter
�� Switch ignition OFF
�� Press and Hold left instrument panel reset button, switch ignition ON to position ‘I’ (accessories)
�� Keep reset button pressed for approximately 5 seconds until the LCD displays ‘RESET SIA’. The
distance to service (e.g. 2150 miles) and the service type (e.g. Inspection/oil service) will be
displayed.
�� Has the ‘Reset Distance’ limit been reached or exceeded?
o NO - Follow instructions in section 2 below
o YES - Follow ‘Reset Distance Counter’ instructions below
Reset Distance counter procedure
�� Press and hold left instrument reset button for 5 seconds. ‘RESET’ will begin to flash on the LCD
display.
�� To reset distance the left hand button should be pressed before the ‘RESET’ message has flashed 5
times
�� The LCD will display ‘END SIA’. Switch ignition off
2) Procedure to check/reset service status – Date counter
�� Press left instrument panel reset button once
�� The LCD will display ‘RESET SIA’ followed by the service due date.
�� Has the ‘Reset Date limit been reached or exceeded?
o NO – Press the left instrument button once. The LCD will display ‘END SIA’ to indicate the
service interval check/reset procedure has been cancelled.
o YES - Follow ‘Reset Date Counter’ instructions below
Reset Date counter procedure
display.
times
Post #298088 Wed May 04 2011 5:07pm
marksgd
Warren It dont work tried it me thinks ill have to go to dealership£££££££. Any other ideas Sad Sad
Post #298089 Wed May 04 2011 5:32pm
Warren G
turn off the car's ignition.
Hold down the reset button on the dash board to zero the mileage.
keep it held in.
turn the car's ignition on - but do not start.
keep the button in for 5 seconds.
a menu will come up - like date/mileage.
let go and then press the button again.
it will toggle through some options - then get to 'rst'
press the button again, and your done
Post #298091 Wed May 04 2011 5:58pm
The above sequence didn't work for my car either, i'm afraid its a trip to the stealers for them to plug it up to their computer to reset it, £50 please Big Cry
Post #298102 Wed May 04 2011 7:34pm
ELD70
BBS sell a reset device, have a search on the D3 forum. (Black Box Solutions)
Post #298119 Wed May 04 2011 9:57pm
ELD70
http://cgi.ebay.co.uk/Discovery-Service-Li...4cf6c61638
Post #298120 Wed May 04 2011 9:59pm
