Home > General > Which rrs??
poolie
2006 Range Rover Sport TDV6 HST Java Black
Which rrs??
Hi new here and am going to buy a rrs. Never had one before so no nothing about them.
I have 20k to spend looking at the models what the difference from se to hse?
Is there anything i should look out for when going to buy?
Any common problems i should look out for?
Do you get a towbar as standard?
What figures mpg 2.7diesel should i expect?
Any help greatly appreciated Wink
Post #297702 Fri Apr 29 2011 8:24pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
if fuel economy is a question then the diesels will be preferable - there are two for the older models a 2.7L V6 and a 3.6L V8. The V8 is the better engine but drinks more and will cost more second hand, the V6 is certainly capable and will be more efficient and cheaper second hand.
HSE has a lot of toys as standard things like a fridge, bluetooth, adaptive cruise control, dynamic response, heated&memory seats etc the list is long and essentially the S version has less, I can't tell you exactly what.
Lots of 'common' problems but then I had a 57 plate for 2.5 years trouble-free. A 'common' issue is knocking front suspension, another one is wonky air suspension. Then you get the usual electrical gremlins of a modern car. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #297732 Sat Apr 30 2011 8:42am
Spighty
Please could you elaborate on what problems I am likely to find on these early cars?
I am In the same boat im looking for a early model. I take it the HSE Is the Model To go for?
Post #297811 Sun May 01 2011 6:02pm
