Home > General > MANAGMENT LIGHT |
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 |
When you cleaned the map sensor did you push some gunk into the hole? Might pay to blast it with a bit of CRC. Also, there may be a possibility that the EGR valves are playing up - give each a light tap. Then start and shut down the engine three times - it takes three starts to clear the engine light. If no luck sounds like it needs to go on a diagnostic machine. |
Fri Apr 29 2011 8:15pm |
tomdigym Member Since: 18 Aug 2010 Location: LARBERT Posts: 41 |
Cleaned out with WD40 and the eye of a needle,everything looked spotless.
Fri Apr 29 2011 8:35pm |
Cheers mate I,ve just went out and stopped and started the engine 4times the light is now out. |
Fri Apr 29 2011 8:42pm |
