Home > Technical > P0108 Fault code |
Probable causes would be..
Sun Apr 24 2011 6:37am |
donchusky Member Since: 30 Jan 2011 Location: Nigeria Posts: 10 |
I'm using a small palm size code reader. Do you happen to know where the MAP sensor is located? Perhaps I should take a look at it and it's wiring. Thanks! |
Sun Apr 24 2011 6:59am |
Follow this thread...
Sun Apr 24 2011 10:04am |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Above thread (and its links) was only really meant for diesel drinkers, never considered v8s. Problem with the TDV6s is the crud recirculated by the EGRs, which AFAIK the petrol engined car's don't have. Worth a look anyway but no idea where the MAP sensor is on a SC engine. |
Sun Apr 24 2011 2:29pm |
I pointed him there just so that he has an idea where the MAP sensor is.
Sun Apr 24 2011 7:29pm |
No worries. |
Sun Apr 24 2011 7:38pm |
Hello everyone! I just solved the problem and thought to share my experience with you guys as a point of reference for the future.
Tue Apr 26 2011 1:40pm |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 |
By 'air manifold' do you mean the inlet manifold ? Just wondering if it's the same item that's all. Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne. |
Thu Apr 28 2011 2:12pm |
yes, MikeS! Please excuse my misrepresentation, I am a heavy duty Diesel mechanic. I was supposed to say "Inlet manifold" in the case of a gasoline engine. |
Thu Apr 28 2011 5:49pm |
Thu Apr 28 2011 8:34pm |
