Home > Maintenance & Modifications > Strange front suspension noises (not knocking) SOLVED! |
[quote=".
Sat Apr 02 2011 3:20pm |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
My sport has started to make a small creaking noise when manoeuvring, Dealer has lubricated and checked everything that moves and now suspect that there is a dry joint or something inside the suspension airbag, got to be booked in for the suspension to be disassembled
Sat Apr 02 2011 4:45pm |
Sat Apr 02 2011 4:46pm |
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 |
The diff started to make noises about a year and a half a go and was replaced under warranty. While it did cure this new noise that had developed at the time, unfortunately it didn't cure an ongoing problem I have had with a resonance/vibration at 1900 RPM. Which I am told is to do with the lock up clutches in the gearbox and is normal. According to the mechanic the diff almost had no oil in it. TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
Sun Apr 03 2011 2:24am |
Thanks for the reply, |
Sun Apr 03 2011 4:11pm |
Hi All,
Fri Apr 08 2011 11:27am |
Mystery Solved. It was a crook wheel bearing (front left).
Thu Apr 21 2011 8:50am |
