Home > General > Front sidelight bulbs |
Yes i have
Sat Apr 02 2011 3:44pm |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 |
me too.looks much better |
Sat Apr 02 2011 3:59pm |
globe195 Member Since: 26 Aug 2010 Location: Bedfordshire Posts: 36 |
Any tips on how to remove the actual headlamp unit to replace the sidelight bulbs? It's fairly straight forward to remove the grill and then lift the two tabs on top of either side of each headlamp but that's where I ground to a halt. I can't seem to pull the unit out as it still seems to be secured fairly tightly in and I don't want to risk any damage? Both of the tabs seem to be pulled up as far as they can go. Appreciate any help. 2006 TDV6 HSE Bonatti Grey,Side Steps,Mud Flaps,20" alloys,LED rear lights,2010 style grill,Soft steering wheel,Land Rover carpets and SS pedals |
Sun Apr 03 2011 7:09pm |
scott7 Member Since: 20 Apr 2009 Location: Scotland Posts: 282 |
You don't pull the tabs all the way up, if you look closely at them the holes in the tabs must line up with the pins on the headlight, push the tabs back down about 5mm and the light will come out, place a rag on the bumper to avoid scratching the paint while you pull the main connector from the back of the light, after that just unscrew the circular bulb cover and pull the sidelight bulb out. |
Sun Apr 03 2011 7:22pm |
Thanks scott7, I'll give it a go when there's some day light. 2006 TDV6 HSE Bonatti Grey,Side Steps,Mud Flaps,20" alloys,LED rear lights,2010 style grill,Soft steering wheel,Land Rover carpets and SS pedals |
Sun Apr 03 2011 7:40pm |
