Home > General > Electrics for towing - is there any?? |
In the rear bumper there is a removable section that hides the recovery eye and the towing electrics (if they have been installed) if you take it off. In this pic it is the section above the red blanking piece for the tow hook
Fri Apr 01 2011 12:06pm |
http://cgi.ebay.co.uk/Range-Rover-Sport-Di...41582983b4
Fri Apr 01 2011 1:08pm |
You don't say if you've removed the panel that's above the towbar fitting - if not there are two large slotted plastic clips which rotate thro. 90degrees and the panel will drop down. your trailer electrics connectors will be visible.
Fri Apr 01 2011 6:35pm |
