![]() | Home > Technical > Bluetooth issue with 2011 |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
sometimes mine says that "phone is not connected" , this is usually when it is in my pocket, and it is probably being blocked by keys , chewing gum wrapper or something in my jacket. usually it is fine if i then connect it up to the ipod lead, then it works fine!
try telling your phone to search again... sometimes mine does it... just a quick search for devices seams to kick start it again.. RRS gone
If it has been working then it's more likely to be a phone problem. 2005 Zambezi TDV6 - Gone but not forgotten
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
Just came out of a meeting and tried again.
My USB input crashed yesterday morning!
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
I have an issue with my bluetooth not automatically pairing with my Iphone each time I enter the car.
James sorry pal, I have no idea of the iphones, only the BB im sure someone will helo you though. |
Ok, how do you auto-pair the BB then?
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Hi James I had the same problem when I first got my car. Needed to get the latest Bluetooth module and software (mine is a 2005 car). I managed to get the dealer to replace it when I first had the car luckily as the Bluetooth worked as you described, they agreed to foot the bill. Wiggs from the disco 3 site can update your bluetooth software to the latest version which should sort all your problems. |
James.
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
On your iphone when AWAY from the car and car locked, under Btooth settings does it list the Landrover as a connection ( ie not connected ) 2014 5.0SC AB
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Once paired you will have a connection called Land Rover in bluetooth menu however I have found with iphone that if you disable bluetooth when away from the car for exmple to save power and then restart the bluetooth you have to re connect in iphone bluetooth settings by selecting connection "Land Rover" If i do not disable BT and get in and out of the car it auto connects - hope this makes sense, writing whilst catching up on T Emmerdale |
do not have that issue with my 3GS always kill my BT on the phone if i know i am not going out in the car 2014 5.0SC AB Gone 5.0 SC |
Thanks for the comments guys....
