Home > General > Air Con |
plasterman Member Since: 03 Nov 2010 Location: staffordshire Posts: 65 |
Have you pressed the auto button in the middle,if you have then it will probably need re gassing. 2007 HSE in black with 22 inch id ones with privacy glass.
Thu Mar 24 2011 8:04pm |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 |
No I didnt have the auto pressed.
Thu Mar 24 2011 8:20pm |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
As long as you haven't pressed the economy button the air conditioner should be running. Selecting auto will mean that it should be running. If the air isn't very cold when you have selected auto and set the temp to min then you probably need to replace the gas in the system as Plasterman has already said. |
Thu Mar 24 2011 11:35pm |
Also.. did you press the air recirculation control button?
Fri Mar 25 2011 12:14am |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
Adjust the blowers then..... It's blasting air out as it wants to get the cabin down to the cold temp you have set, once there they'll ease off |
Fri Mar 25 2011 8:47am |
