Home > Maintenance & Modifications > Snow foaming guide for a Foxy lady.
ChrisP
Thought I'd do a run through for Foxy and anyone else who may be interested.
1st the before shot
The snow foam gun
Attached to the pressure washer
1st coat of foam
Rinsed off
2nd coat of foam
Finished article after a shampoo and final detail spray ,absolutely gleaming
 MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #292835 Sat Mar 19 2011 12:00pm
paulo_martins
Nice work. Cool http://paulomartinsphotography.tumblr.com
Post #292839 Sat Mar 19 2011 12:09pm
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
I use the same snowfoam lance,do you use the valet-pro ph neutral foam.?
Andy.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #292843 Sat Mar 19 2011 12:34pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Give your cars a good wax,then see what happens with the snow foam Wink
Post #292846 Sat Mar 19 2011 12:44pm
V8 andy
I use the ph neutral snow foam so when ive waxed it it does'nt take the wax off.
Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
Post #292850 Sat Mar 19 2011 1:30pm
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
question, when filling the snow foam bottle do you fill it with concentrated solution or do you pre mix it with water ?
Post #292851 Sat Mar 19 2011 1:35pm
DSL
I need to replace the cheap & crappy snow foam thingie that came with the Wickes pressure washer (Lavor fitting ISTR), anyone got a good place in interwebland to buy one? Well wouldn't want a dirty pikeymobile after Guava got it so gleaming! Whistle
Post #292852 Sat Mar 19 2011 1:37pm
V8 andy
I usually put a couple of inch of snowfoam then top up with hot water,but if car is really bad i put a bit more foam in it.
Post #292854 Sat Mar 19 2011 1:44pm
mrfixit
I cant get the snow foam to stick to mine once I've waxed it,thats what I meant
Post #292855 Sat Mar 19 2011 1:49pm
ChrisP
Andy.
Andy,
Just using the Elite own brand which came with the gun at the moment but perhaps I should try yours once I've waxed it don't want to wash that off?
I diluted it 50/50 1st attempt,used it neat this week and the foam was much thicker.
Need some tips now for the black plastic trim under the doors anybody recommend what they are using?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #292870 Sat Mar 19 2011 3:20pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
I've got the same snowfoam lance too. Do you just dry the car straight away? I always worry about swirl marks from not washing it properly.
The instructions on my snow foam say to pre-wet the car first, do you not do that either? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #292871 Sat Mar 19 2011 3:20pm
ChrisP
Rich,I snow foamed it dry because I was told if it was wet it would just run straight off.
I dry it straight away after washing with Meguiars shampoo and conditioner with a large MF towel. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #292873 Sat Mar 19 2011 3:38pm
smurf
DSL :- i use www.autobrite for my cleaning products
CHRISP :- currently using autoglym bumper care for the rubber/plastic bits at the bottom of the doors,but only because i have had it ages.
Post #292874 Sat Mar 19 2011 3:42pm
V8 andy
I dont dry the car as the foam does'nt get all muck off,so if you dry with leather of other cloth you could end up scratching the paint work,i usually snow foam then clay then wash with dodo juice then polish with meguires then finnish off with meguires NXT 2.0 tech-wax.& 8 hours later you should have a nice shinny car.
Post #292890 Sat Mar 19 2011 6:58pm
RichardM
Thanks guys. I only got the foam lance last weekend so I wasn't sure what's best. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #292923 Sat Mar 19 2011 8:33pm
