Home > Maintenance & Modifications > Jacks
Jacks
I've just discovered my mini 2 tonne trolley jack doesn't have the reach required to lift the Sport.
I was just about to purchase this
http://www.halfords.com/webapp/wcs/stores/...yId_165727
When I saw this
http://www.alltoolsdirect.co.uk/draper-3-t...2284-p.asp
Anyone have a recommendations? RRS gone
Post #291377 Mon Mar 07 2011 3:14pm
Neither will do. You need a min 3 tonne jack and that air jack has been tried and tested and it doesn't work. There are other airjacks that do but are expensive. 2005 Zambezi TDV6 - Gone but not forgotten
Post #291378 Mon Mar 07 2011 3:44pm
Can I give one bit of advise - when lifting always put your spare/removed wheel under the RRS, next to jack just in case the jack gives way. Not only will this protect your car it might protect you. 2005 Zambezi TDV6 - Gone but not forgotten
Post #291379 Mon Mar 07 2011 3:47pm
scarey
i have one of these to lift my full fat, works well...
http://www.machinemart.co.uk/shop/product/...sion-jacks
Post #291380 Mon Mar 07 2011 3:49pm
(I have axle stands which I will use) RRS gone
Post #291382 Mon Mar 07 2011 3:53pm
shepp
6 tonne bottle jack usually works fine, compact and fairly cheap
Post #291394 Mon Mar 07 2011 5:52pm
and highly unstable! 2005 Zambezi TDV6 - Gone but not forgotten
Post #291396 Mon Mar 07 2011 5:59pm
DSL
Get yourself one of these bad boys, lift capacity and reach enough. I use it to lift the D3 for wheel changing regularly and it is excellent. I lift on the chassis then drop onto an 3t axle stand for changing.
They were available from Costco but don't know if that is still the case.
Post #291400 Mon Mar 07 2011 6:40pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Best to Jack off the axle as said above. Much less height required from the jack that way. Getting one with a higher lift to jack on the landrover jack points bringings its own problems with stability.
I use a 2 tonne lift with no problems and then axle stands. Some like to be extra safe and will shudder at that but the whole car weighs less than 3 tonne and your not jacking the whole car at any time.
Post #291417 Mon Mar 07 2011 8:44pm
