Home > Maintenance & Modifications > Fitting Brembo calipers???
BIG DJ
Is it a straight forward process of just removing the old calipers and fitting Brembo ones or is there more to it?
Thanks
Adam Thumbs Up
Post #289197 Tue Feb 15 2011 4:55pm
keiphers
United States
Re: Fitting Brembo calipers???
Thanks
Adam Thumbs Up
It's relatively straight forward but requires changing the whole brake kit (not just the calipers)...
Post #289210 Tue Feb 15 2011 6:48pm
BIG DJ
When you say brake kit? Do you know exactly what's needed?
Post #289211 Tue Feb 15 2011 6:54pm
keiphers
United States
Here's an example from one of the (US) Brembo Gran Turismo brake upgrade kits:
http://www.brembo.com/CatalogoHPGT/DetailP...idLingua=1
Post #289309 Wed Feb 16 2011 3:17pm
Yes I was thinking that new thicker disks were also required as well as calipers... RRS gone
Post #289312 Wed Feb 16 2011 3:24pm
sandman_30
United Kingdom 2006 Range Rover Sport Supercharged HSE Java Black
I have had my brakes upgraded to brembos 2 weeks ago. I have the 2.7tdv6 sport. Bought the calipers and was given the dirt guards you can modify your standard ones but since I was given the genuine lot I didnt bother. I bought a set of 380mm discs and pads for £125 (Brake World) and it was a straight fit no problems at all. Look great. Would recommend it to all who are thinking of doing it.
Post #290550 Sun Feb 27 2011 11:22pm
avos
Was planning to do this already for some time, but it is good to know that it is a straight fit. Will do mine in a couple of weeks. RRS SDV6 HEV Dynamic
XKR 700 BHP with Twin-screw and LSD
Post #290578 Mon Feb 28 2011 10:27am
SR71
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Can I ask what the financial damage was on the calipers?
This is about the only mod I'd do on the TDV6. 00 Audi B5 S4 MRC550'ed
08 RRS TDV6 HSE
03 Kawasaki ZX12R 1287cc
04 Audi 8P A3 2.0 TDi S-line
Post #290803 Tue Mar 01 2011 9:32pm
sandman_30
Got mine for £210.
Post #290812 Tue Mar 01 2011 11:03pm
BIG DJ
Thanks guys Thumbs Up
Post #291784 Thu Mar 10 2011 10:04am
avos
Just replaced my standard calipers with the brembos, and can also confirm it is a straight swap.
The rotors/pads had to be changed anyow, so it was a good moment to also swap the calipers
Here is a picture showing the original rotor compared to the brembo (360mm) one:
Post #293754 Sat Mar 26 2011 1:11pm
jaydeeboro
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi folks,
Are the brembo's much better than the small brakes? I guess they should be but other people seem to be just doing this because they look nice. Is it worth doing for braking's sake if I'm not bothered about looks?
Cheers in advance
Post #300937 Fri May 27 2011 10:54am
Rogue GTR
jaydeeboro wrote:
Hi folks,
Cheers in advance
Actually i am very anal about brakes, my JDM Subaru STi Specs C came equipped with standard Brambo's 4 Pistons front & 2 pistons rear calipers on huge rotors- i was severely lacking when one drives it robustly.
05 'E46 M3 had a entire brake change, threw the factory items out & changed to AP Racing Slotted Rotors anchored to 6 pistons front & 4 pistons rear while rotors are FULL Floating design. However when under intense usage, it still protest like a pig & has brake fad!
07'Mk 5 VW Golf GTi, threw out the largest production factory brakes come fitted to any ride (single piston calipers) & ponk in the AP Racing Pro5000+ Endurance calipers & mated it with AP Racing J Hook vane rotors that is Full Free Floating- now this is 1 serious kit, one can abuse it like there's No Tomorrow & it'll stop everytime & anytime like hitting a brick wall when you ppaddle to the metal on you brake peddle.
08-09'Nissan R35 GTR, i bin the factory brakes (it's supposed to be even better than the Porsche Turbos non ceremic) after 4000km of intense usage & all the 4 brake rotors were shot thru & thru with the drilled holes cracked! Changed it too Endless Forged Monoblock Big Brake kit & it's been serving me just fine all these years without any issues. Mind you, porsche Cup car (race cars uses the Endless RF650 Brake fluids & pads) uses Endless fm factory!
Now, if you do spirited driving & hard braking into corners (trail braking) then you'll need the best money can get for your ride for i believe you'll agree that a Range Rover has lots of dead weight to lag around hence it'll stressed the brakes much more than 'lesser'cars.
Post #302160 Tue Jun 07 2011 2:04pm
tempestv8
Australia
I assume that the wheels may also need to be changed to accomodate the bigger brakes...
I understand 19" wheels is the minimum for the TDV8 because of the Brembo brakes. 1999 Discovery II V8 auto
Post #304209 Tue Jun 28 2011 3:01am
