Home > General > Number plate size |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 |
Is it the standard one's your after?
Sat Feb 12 2011 1:45pm |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 |
The Rear is 536x153mm The front Standard.
Sat Feb 12 2011 1:47pm |
jamiequ1 Member Since: 23 Jan 2011 Location: london Posts: 58 |
So what does the car cone with from new , and to people change them because they don't like the look of the shaped one? |
Sat Feb 12 2011 4:16pm |
They come with standard. |
Sat Feb 12 2011 4:20pm |
But there are two different styles for the rear - some are shaped like Focus and Rover75's like this
Sat Feb 12 2011 4:47pm |
Royle Member Since: 24 Nov 2010 Location: Perth Posts: 211 |
On mine I had the "wing" effect plate (not sure the accurate name is) I got mine from Demon Plates. Once you have your reg in go to plate size, model specific and choose. You can just use the standard one obviously but I think that the shaped one finishes it off.
Sat Feb 12 2011 4:59pm |
Thanks for that Tim , it does look as if there is something missing when a standard plate is put on the rear, look like it has been put on as an after thought. |
Sat Feb 12 2011 6:12pm |
Thanks for that Royal , just the job |
Sat Feb 12 2011 7:11pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Jamie it came with the shaped plate (like Rover 75) but I swapped for standard as I prefer it. Bought from No 1 showplates website. |
Mon Feb 14 2011 3:44pm |
Mine came with the standard oversized rear plate and I changed for the wing style
Mon Feb 14 2011 4:49pm |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 |
just to confuse you even more,i have just ordered a "wing" type plate but it looks smaller than the one's in the photo's.when i fit it i will try to post a photo of it,due for collection thursday. |
Tue Feb 15 2011 11:43am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
I am happy to be wrong but all the listings show the following as the rear plate size option??
Sat Oct 06 2018 10:44pm |
I have the standard size on mine,it’s the only size my supplier does.plus I prefer it as the bigger ones show too much yellow.
Sun Oct 07 2018 6:40am |
Jeez, that number plate doesn’t half get around......
Sun Oct 07 2018 12:41pm |
