Home > Maintenance & Modifications > replacement drive belts 2.7 td
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
would appreciate any help on finding out if I could do any of these drive belts at home and if so which ones
car is a 2007 model and is coming up for 105,000 miles
Post #288359 Tue Feb 08 2011 4:17am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
There are two belts on a RRS one at the front of the engine and one at the rear
I believe that if you take your car to a dealer they will take the body off to replace the cambelts roughly £800
The rear belt is the problem one which if you do your self then you will require a special tool about £100. However if not replaced and fails does not do do any engine damage, engine will stop due to no fuel.
I'm sure Bobby will be able to help with more detailed information
Post #288383 Tue Feb 08 2011 11:08am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I think it is quite straightforward once you have done this Rolling with laughter
Post #288413 Tue Feb 08 2011 1:49pm
ronniet101
i understand that is the only way to take the rear belt of, but that the front camshaft belt is more straightforward.
would be interesting to know definitively before I try and start
Post #288476 Tue Feb 08 2011 10:26pm
ronniet101
im convinced that the job is straightforward and that the rear belt is fiddly but doesnt need the body off ( this was confirmed by my local stealer) and a good article on the Disco3 website
couple of questions if anyone can help...
as you look from the front of the car does the fan come off by turning clockwise or anti clockwise as you look at it
also is the crankshaft pulley likely to be absolutely solid...any ideas how to get of without a puller..anyone got recent experience
also how do you remove the accessory belt, im assuming there is a moveable tensioner, has anyone a pic of which one this is and which direction it moves to release
ive looked online and only special tools seem to be timing pin to secure camshafts, tool for locking crankshaft via starter, tools for the fan and thats it apart from normal spanners and loads of patience
Post #288570 Wed Feb 09 2011 5:39pm
ronniet101
Im going to be doing the camshaft belts at end of next week, once complete if anyone is interested in hiring the tools from me ( caamshaft locking pins and fan removal tools) please let me know..was thinking of £8 + postage for 2 weeks
Post #288698 Thu Feb 10 2011 11:44pm
1JBS
Good luck..
Post #288714 Fri Feb 11 2011 9:00am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
How about taking some pics as you go and we can then all share the experience Thumbs Up
Post #288879 Sat Feb 12 2011 10:45am
ronniet101
there is already a few pages of pics on the disco3 web site showing the cam belts being changed
Post #289151 Tue Feb 15 2011 12:28am
ronniet101
Post #289152 Tue Feb 15 2011 12:28am
ronniet101
the belt has been changed, well the front one at least. The job was done in a few hours...very straight forward.
I have the special tools for the camshaft locking and for the fan removal, both are essential to do the job. so if anyone would like to do the job themselves it would be £8 excluding the postage and a £2 donation to the RRSport website for the hire of the tools, this would be for a week once the tools have been received. not asking for deposits as we should have some trust in each other on the site
Let me know if anyone fancies doing the job themselves.
Incidentally the old belt was in near perfect condition
just the rear one now...and special tools arent required for that one.
Post #289947 Wed Feb 23 2011 12:16am
Well done Thumbs Up just out of intrest, what mileage has the vehicle done?
Ady
Post #289987 Wed Feb 23 2011 11:59am
ronniet101
its now got 108,000 on the clock
Post #289991 Wed Feb 23 2011 1:00pm
Cheers Thumbs Up
Post #290027 Wed Feb 23 2011 4:46pm
ronniet101
since changing the belt the car feels more responsive, press the accelerator and the pick up is a lot quicker
Post #290612 Mon Feb 28 2011 2:32pm
