Home > General > NAVIGATION PROBLEM |
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 |
Make sure you set the nav to the right country, default is Belgium. |
Mon Jan 31 2011 11:43pm |
abs109 Member Since: 30 Jul 2008 Location: london Posts: 9 |
Yes i have it on uk map still same message unable to calculate your route, any idea how to get the nav disc out from under the seat.
Wed Feb 02 2011 10:37pm |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
Move passenger seat forwards and up, you can then reach the drive from the rear passenger footwell. It should have a lock switch to prevent the disc being accidentally ejected. Move this and then press eject.
Thu Feb 03 2011 3:27pm |
took the disc out and back in again, still the same problem. the pointer in the screen is moving when im driving so its working but unable to calculate any route. could it be the 22' wheels i recently upgraded to.
Sat Feb 12 2011 11:58am |
Linko Member Since: 10 Sep 2010 Location: Shropshire Posts: 61 |
Hi abs,
Sat Feb 12 2011 1:18pm |
matrix13 Member Since: 29 Aug 2011 Location: avon Posts: 8 |
my sat nav sometimes wont let me put in address is this common |
Mon Aug 29 2011 10:40pm |
