![]() | Home > Technical > Anyone Got A Bluetooth Wiring Diagram |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Anyone ? |
lee157 Member Since: 07 May 2010 Location: in the middle Posts: 19 ![]() ![]() |
http://www.rrsport.co.uk/gallery/albums/us...system.pdf
Wow, thats more complicated that i thought |
I had mine retrofitted in my D3 by wiggs from the disco3 forum, but all it needed for the bluetooth to work was main power to pin 17 & 18 fed from fuse 52, power to pin 16 from the infotainment relay which is fuse 58, a negative to pin 33 & 34, and your MOST in and out, according to the wiring diagram.
Hi Lee
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
How do you know if your RRS is prepped for bluetooth? |
There will be buttons to take and end phone calls on the underside of the steering wheel, right hand side I think.
Cheers,yes I have those,but what is the connection point for under the armrest?Sorry for the questions but Its new to me. |
There are a few cradles available that will plug in there and you can have the phone hard connected to the RRS so it charges the phone whilst you drive.
The "phone removed" bit seems to point towards the phone connection in the centre arm rest, and according to landrover owner info "Note: A phone docked in the cradle will always take priority over wireless operation." So i'm wondering if there is an error with the centre arm rest cradle, it might be worth removing this if you still have one fitted. Landrover owner info here http://www.rrsport.co.uk/gallery/albums/us...ephone.pdf Lee |
Hi Lee
Hi Lee
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Hi Carlos
Hi Simon
