Home > Technical > Brake pads: strange signs of wear
PHYLRRS
Netherlands 2006 Range Rover Sport TDV6 HSE Bonatti Grey
had squeaking noise coming from the left rear wheel. My brake pad was totally worn and only metal left. strange enough was only the outside brake pad. The other brake pads are fine ( ca 5mm thick).
I noticed the sensor is applied to only on the rear right wheel. the left one has no sensor, so didn't get any warning on my display.
They dealer said they replaced all the brake pads (Front and left). isn't strange that only 1 brake pad is worn? could it be possible they forgot one the replace Confused
Post #287055 Thu Jan 27 2011 12:06am
Tboner
Sticking piston on the caliper or disc ? 2014 5.0SC AB
Gone 5.0 SC
Post #287057 Thu Jan 27 2011 12:08am
