![]() | Home > General > Quick Tyre Question.... |
No |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 ![]() ![]() ![]() |
Yes... |
KR1005 Member Since: 03 May 2010 Location: Hong Kong Posts: 61 ![]() ![]() ![]() |
Why did you put back the 20"? Is it because of ride quailty? Is there much different? I have 22"and too are thinking putting back on 20". What tyre did you have on your 22"? |
8 CDC Member Since: 21 Apr 2010 Location: Sth Lanarkshire Posts: 59 ![]() ![]() ![]() |
Thanks Alex. Just heard differing views on 40 & 45 profiles.
No problem, Just depends on what you want the tyre for.... Just road use or a bit of play as well...
I have 22"and my tyres are 285/35/22 does that mean is no good to the bushes? I don't take it off road just town use. |
It is a veritable can of worms, this one....
If you are inside of warranty stay away from the 22s; I hear LR is getting picky about issues that could be possibly related (blamed on) to low profiles, even down to the make of tyre on a 20inch rim.
If rrs bushes can't handle the 35 profile of 22" wheels then it just goes to show how bad the range rover sport is built and if thats the case then its not fit for purpose, its a bloody 4x4 for heavens sake, designed to off road. |
raadar Member Since: 07 Oct 2010 Location: sunshinecoastQ Posts: 38 ![]() ![]() |
had a set of 275/45R20 Yokohama Advan SQ7 on my RRStdv8. This is the same tyre as used on cayenne and Q7 and was chosen for the stiffer sidewalls and slightly higher profile to cope with ocassional transgressions onto gravel roads and road shoulders, as well as our substandard road conditions in Aus.
