![]() | Home > General > Final word on front suspension knocking |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
I think it may be quite a long time before there is the "final word" on this issue. I am a verteran of this matter having suffered knocking on 2 RRS's. One was a very early TDv6 without DR and the other is now a 4 year old TDv8 with DR. The dealer has tried every mod that LR issued and each time any apparent "fix" lasts a few months (or in some cases weeks) before the knock returns. My issue now seems to be identfied as simply the bushes on the front anti roll bars which appear to wear out rapidly. The rate of wear seems to accelerate when the car is wearing 20" wheels in warmer temperatures and they last longer when she is on 19" wheels in winter. RRS TDv8 HSE Rimini
Boo Member Since: 20 Oct 2010 Location: Hertfordshire Posts: 28 ![]() ![]() |
This fixed it for me:
spitfire Member Since: 17 Jan 2011 Location: UT Posts: 6 ![]() ![]() ![]() |
Boo you mentioned replacing both lower control arms did you have issues with the just the lower ball joints or were your arm bushings bad as well? My local dealer only replaced the lower ball joints in an attempt to fix the knocking as the arm bushings seemed fine to them. You also mentioned replacing the sway bar bushings which I assume was part #: RVU500011. Did they replace the sway bar mounting brackets because of an improved design? If so, I'd be interested to know what part number they installed so I can have my dealer hopefully do the same. |
lee157 Member Since: 07 May 2010 Location: in the middle Posts: 19 ![]() ![]() |
Hi guys, i do apologise if this has already been mentioned as im new to this site and also come from the sister Disco3 site.
Before I got my RRS S/C I had a 2006 D3 with what I thought was the same inner ball joint problems with the tie rods. The dealer replaced them but it didn't fix the problem. The actual problem was internal to the steering rack. There was excessive play at both ends of the rack where the inner ball joints are connected. It was a pain to diagnose as it is very difficult to tell the difference between play in the inner ball joint and the end of the rack housing. Needless to say, a new rack solved the problem along with the infamous lower steering column fix to address excessive free play in sliding joint but in the end it worked out.
