Home > Maintenance & Modifications > Mod to make rear map / reading lights come on?
Page 1 of 3 123>
big pimp
Another one from me!
Just wondering if anyone has done a mod, or if it's even possible to make the rear lights come on when the doors open
Just find it really weird they don't do it automatically!
Thanks MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #285786 Thu Jan 13 2011 9:33pm
simon1233
Check out the tips and tricks section and I think there is also a FAQ for this
Post #285820 Fri Jan 14 2011 8:39am
Bobby
http://www.rrsport.co.uk/forum/topic5537.html Question Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #285832 Fri Jan 14 2011 11:27am
simon1233
This thread has a link to the text of AlanM's solution to making the lights come on in the rear with the other courtesy lights - no photo's though Big Cry
http://rrsport.co.uk/forum/topic5550.html
And here is the link to the instructions. I will be doing this myself (hopefully this weekend) after I get some diodes from Maplins. I think I will pick up the feed from the light in the boot as this should involve less removal of trim panels.
http://web.archive.org/web/20080328150403/...ights.html
Simon
Post #285834 Fri Jan 14 2011 11:34am
Try send Alan a pm or email - he might still have the instructions.
Nice hotel though. 2005 Zambezi TDV6 - Gone but not forgotten
Post #285835 Fri Jan 14 2011 11:36am
big pimp
thanks very much guys - i did honestly look for the topic, but couldn't find it! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #285840 Fri Jan 14 2011 12:13pm
simon1233
Have done the modification this afternoon. Took about 90 minutes. Would have been quicker if I was competent with a soldering iron Laughing
Popped rear reading lights out of their sockets and removed the black plug. In order to reverse the switched feed you just need to remove part of the plug - this just pops off when persuaded by a small screwdriver. I had to adjust the pins in the socket slightly (pushed them down by a mm with screwdriver) so that the plug would go back in in the reversed position and the switch now interrupts the +ve feed. Did this both sides and then went to the boot. Removed the rubber seal from the opening across the top and down the offside of the car. Pushed a wire to each reading light through the headlining and took them both down the side of the trim panels to the opening where the boot light is located. I joined the two wires together and soldered in a 5404 diode. To the other end of the diode I soldered a small wire which was then joined with a Lucas clip to the live feed at the back of the courtesy light in the boot (violet wire as already mentioned).
Back at the rear lights the new wire was soldered onto the live side of the bulb (in my case left) after the switch. Now the rear reading lights come on with the other courtesy lights and also still work independently as reading lights without causing other lights to come on.
Going in from the boot meant that there was no removal of trim panels.
Thanks to Alan for his original work and the other contributors re the diode etc. Bow down Thumbs Up
Post #285963 Sat Jan 15 2011 7:09pm
Sizzle TDV8
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Sounds a lot easier than removing all the trim Simon. Top job.
You got any pics of the connections you made?? 2007 RRS TDV8 Stornaway Grey with lots of smiles..
2007 Audi A4 2.0T Cabriolet
Missing - 2008 Suzuki GSX-R 750
Post #286002 Sun Jan 16 2011 8:29am
simon1233
Hi Sizzle
It was rainig whilst I was doing the job so I didn't take any photo's.
I'll try and get some photos and upload them later during the week if it stays dry
Simon
Post #286013 Sun Jan 16 2011 10:13am
flydive
Simon, that looks easier than previous version, I'll probably get on it next week.
Thanks Thumbs Up '08 RRS TDV8
Post #286014 Sun Jan 16 2011 10:19am
big pimp
Brilliant Simon - I'm looking forward to seeing the photos.
Need to get my wee soldering skills refreshed! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #286016 Sun Jan 16 2011 10:52am
simon1233
Hi Guys, attached are the photo's of the modification. Please ignore the poor quality of the soldering - It will be improved later this week when I get some solder with flux (and another pair of hands to hold the light whilst I solder the wire onto the bulb holder. I did notice that if you just jam the wire into the side of the bulb holder this works as well, but I am going to solder mine so that the wire cannot vibrate loose.
Not sure if the above files will be shown at full resolution, but the files are in my gallery Very Happy
Post #286137 Mon Jan 17 2011 12:13pm
Sizzle TDV8
Top man Simon, that looks far easier than the other way of doing it.
Just out of interest what gauge cable did you use.
Thanks. 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #286189 Mon Jan 17 2011 8:33pm
big pimp
Awesome looking dude!
I nominate this already for most informative post of the year! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #286202 Mon Jan 17 2011 9:50pm
simon1233
Hi Sizzle
The marking on the packet says 16/0.2?
Either way it was £2:50 for 10m from Maplin
Sorry for the lack of technical knowledge
Simon
Post #286213 Mon Jan 17 2011 11:31pm
Page 1 of 3 123>
