![]() | Home > General > Front screen pulsating - anybody else had this?? |
plasterman Member Since: 03 Nov 2010 Location: staffordshire Posts: 65 ![]() ![]() ![]() |
I had this the other night,started the rrs up dash lit up like a xmas tree,sat nav flashing wouldnt change out of 2nd gear,looked around and the kids and mrs had the heated seats on.I would think its battery related getting low,i took mine out for a good run in the day no heaters on or lights and it seems to have done the trick. 2007 HSE in black with 22 inch id ones with privacy glass.
Mine used to do this at dusk..............must be a sensor somewhere that decides bright or not so.
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Mine does this every so often as well. I think the sensor that controls the brightness must get confused every so often... |
