![]() | Home > Australia & New Zealand > Auxiliary Fuel Tanks |
Has anyone fitted an auxiliary fuel tank to their RRS? I was pottering around under my car looking at spots that may be suitable. The obvious spot is the spare wheel well and I assume a D3 tank would fit there but then you have to sort out what to do with the spare. If the exhaust was changed there would probably be a spot for about 60 litres beside the main tank on the passenger side of the car but I assume that there is not even a D3 tank for this location.
Jimmy Salsa Member Since: 03 Mar 2009 Location: Hunter Valley Posts: 257 ![]() ![]() |
I'd also be interested in a solution.
When swapping wheels around yesterday I had a good look around the wheel well (who designed the spare arrangement that means you have to lower the wheel to put air in it - but I digress).
bigneil Member Since: 01 Jan 2011 Location: Christchurch Posts: 6 ![]() ![]() |
I,m new so dont bite my head off,
Neil,
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Forum member Riminired has the 4x4 intelligence swing away wheel carrier fitted:
As i live in NZ we are not used to these huge trips |
You need to use a 3rd party listing site such as Photobucket. You put your pic on that site and then it will give you a range of links for listing gear - copy the link for forums and paste the link in your post on this site. Before posting look at the preview to check all is Ok then post.
\ Thanks - it is good to see someone making some stuff for the RRS. However I don't think a spare wheel carrier will look right. Don't look good on a RR classic or a P38 - but does look good on a Disco. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
Not sure about the 4x4 Intelligence carrier, but with the Opposite Lock version (for the D4) you can remove the arm when not in use, leaving just a small stub protruding from the bumper and the latch. Might help with the aesthetics?
I am just waiting for all you guys to try this stuff and report back how it goes. |
640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231 ![]() ![]() ![]() |
I spoke to Opposite Lock about the rear wheel carrier and the long-range fuel tank and they can do both installed for about $3,200. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres. |
raadar Member Since: 07 Oct 2010 Location: sunshinecoastQ Posts: 38 ![]() ![]() |
disco4x4,
