Home > General > parking sensors front/rear replace help please
ptwroofing
can any one tell me please want to replace parking sensors front and rear and need some advice about removing front/rear bumpers or some other way of getting to these Censored just really need to no how to take bumpers off really cant be that hard as a pal i know just had his colour coded and they stripped the lot cheers paul. paul
Post #284768 Tue Jan 04 2011 8:44pm
Bobby
These issues have been discussed umpteen times - do a search please! Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #284789 Tue Jan 04 2011 11:39pm
simonw007
United Kingdom 2005 Range Rover Sport Supercharged Zermatt Silver
Luckily Bobby has posted the front and rear bumper cover removal procedures in his gallery:
http://www.rrsport.co.uk/gallery/albums/us...0Cover.pdf
Thank you Bobby!
I removed my front bumper cover a couple of days ago for access to the parking sensor wiring. Easy to do with a second pair of hands and the car with suspension set in the highest position. Rear bumper cover looks like it might take a little more time but still a straight forward process.
Post #284793 Tue Jan 04 2011 11:48pm
ptwroofing
many thanks did you have to have the clock reset or does the replacement of the faulty sensors correct the message on the dash cheers paul paul
Post #284838 Wed Jan 05 2011 12:53pm
simonw007
From reading through other posts I believe the replacement of the faulty sensor is enough and then the control unit reverts to normal operation. I wont be able to test this for sure until my replacement sensors arrive and I change it over.
My sensor problem is an intermittent error in the dash saying the front pdc is inactive. I opted to check the wiring and then order replacement sensors to swap over, probably this weekend. The intermittent error is worst in damp conditions and a real PITA because it blocks the rear sensors from working.
Good luck with yours, a bit of searching here and on the disco3 site reaps massive rewards in the form of really good info. I have learnt a lot in the last couple of months since being a RRS owner and browsing these great resources.
Simon
Post #284841 Wed Jan 05 2011 1:16pm
ptwroofing
got the exact same problem front parking ade inactive flashing light with long tone this has stopped front and rear sensors so not sure which ones to check front or rear or just replace all as 4 new sensors on e bay only £60 paul
Post #284846 Wed Jan 05 2011 1:42pm
merwiz
I had the same fault, but traced it to the offside front sensor.
I managed to swap it without removing the bumper, its a tight squeeze but do-able! I keep telling myself 'It's a toy'
But I've broken quite a lot of toys in my time.....
Post #284847 Wed Jan 05 2011 2:07pm
ptwroofing
I put the car in reverse like someone else said on this site and listen for the clicking on each sensor and they said the 1 that's not clicking is the faulty 1 but all mine are clicking front and rear so do you think it could be a fault on the wires somewhere Sad paul
Post #284857 Wed Jan 05 2011 2:41pm
simonw007
Sorry, I don't know the answer to the sensor clicking question. However, I have ordered the 4 oem sensor set from ebay for £60 and plan to change all four fronts.
Bit of a sledge hammer to crack a nut approach but all my sensors are discoloured so aiming to save time and money in the long run by changing all 4 on the front.
Simon
Post #284919 Wed Jan 05 2011 9:19pm
